Dead Gimbal ?
Discussion in '2 Axis Gimbal' started by Jon Ford, Jun 4, 2013.
  1. Jon Ford
    Jon Ford New Member
    Jun 4, 2013
    A big hello to all from southern France!
    Having assembled and flown my cinestar 8 a few times I felt ready to use the 2 axis gimbal. Unfortunately when I connected it up...nothing happens. It's strange as when I had tested it on the bench a few months ago it did work.
    I could be doing something very stupid here...In fact that's more than likely. Is there a way to disable/enable the gimbal? If there is I can't see it. Fingers crossed for something simple.
    thanks in advance
    Jon
  2. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    Hard to tell what's going on without being there. How are you running power to the gimbal?
  3. Jon Ford
    Jon Ford New Member
    Jun 4, 2013
    It's being powered through the FC. I did measure 5v coming out of the FC but I don't know about the third (orange) wire.
    10,351
    1,160
    Can you also post some images showing the wiring to the servos etc, Jon, and clarify a bit further? Is there any power going to the servos? Are you using Radians to stabilize or an MK FC board? It sounds like it's not even getting any power.
  5. Jon Ford
    Jon Ford New Member
    Jun 4, 2013
    Hi Andy Here's a pic of where the roll servo is plugged in. The nick is on the opposite side of the FC. I measured 5v coming off the FC so it does have power. I'm not sure abot the signal (orange wire) though. I'm not using Radians......yet.
    thanks
    Jon
    10,351
    1,160
    Jon: Well, that certainly does seem to be the correct connector for the roll servo (SV3) according to the diagram at http://www.mikrokopter.de/ucwiki/en/FlightCtrl_ME_2_1 (the diagram needs to be rotated 180 degrees to match the orientation of your image.
    The problem that there's no easy way to debug a servo output without access to an oscilloscope so you can see whether there an pulses being output on the orange wire.
    If you connect up MK Tool to the FC, and use the 3D button (to get the 3D replica of a copter) does the replica track the motions of the FC?
    I'm just grasping at straws to try and find a way to do some basic diagnosis here....and the first thing I suspect is the Flight Control board isn't behaving the way it should....so isn't driving the servo outputs correctly....
    You might also want to check out how to use MK Tools' "Scope" feature and just get a sense of whether the accelerometers are working ok.
  7. Jon Ford
    Jon Ford New Member
    Jun 4, 2013
    Thanks Andy. I tried the 3D option and it seems to track the copter perfectly.
    I have to say I don't really understand what I'm looking at with the scope feature but to describe what I saw; The upper line didn't do anything when I moved the copter but the lower line did move very slightly and displayed some short lines when the copter was moved. Maybe there is something very basic that I've overlooked, my thought being, I'm virtually computer illiterate, so anythings possible.
    Jon
  8. Adam Paugh
    Adam Paugh Distributor
    323
    78
    Hello Jon,
    With the kopter all powered up and your transmitter on, have you calibrated the gyro with the stick command from the transmitter (full throttle/full left rudder)?
    Greetings,
    Adam
  9. Andy Johnson-Laird
    10,351
    1,160
    Adam raises a very good point: Have you also calibrated the accelerometers? This is a one time thing....the calibrating the gyros that Adam mentions is once each flight before you start the motors.
    You might find this web page helpful: http://www.mikrokopter.de/ucwiki/en/Mikrokopter-Get-started
  10. Jon Ford
    Jon Ford New Member
    Jun 4, 2013
    Hi Adam
    You're spot on! It works!!! Thank you!
    I didn't know I had to calibrate the gyro to get the gimbal working....well I do now.
    Many thanks again for all your help
    Jon
  11. Andy Johnson-Laird
    10,351
    1,160
    The reason you have to calibrate the gyro is otherwise the FC board doesn't know how to move the gimbal to maintain the right angle with respect to the ground. :)
  12. Jon Ford
    Jon Ford New Member
    Jun 4, 2013
    Yes, now you say it, it makes complete sense.
    Now I'm worried I haven't calibrated the accelerometers :eek:. I followed your excellent dvd to the letter, plus it flies great! I'm going to double check anyway.
    thanks
    Jon
  13. Andy Johnson-Laird
    10,351
    1,160
    Thanks for the kind words about the DVD, Jon -- now you've got me worried -- I could have sworn I covered calibrating the ACC...please know if I did not! :)
  14. Jon Ford
    Jon Ford New Member
    Jun 4, 2013
    Don't worry, I just checked on the DVD, you did cover calibrating the ACC. That's good news for me as this means I would have done it too.:) Thanks
    Jon
