Custom Movi M10 battery plates
Discussion in 'MōVI M10' started by Dana Neibert, Feb 13, 2014.
  1. Dana Neibert
    Dana Neibert Member
    Dec 9, 2013
    35
    We wanted to keep the weight of the Movi down so we created some battery mounting plates that use the same batteries as the Movi to power our accessories. The plates are ultra secure and feature p-tap connectors. We love the Movi batteries because they are ultra lightweight and pack a lot of power. Check the plates out:
  2. Phil Planta
    Phil Planta New Member
    Oct 17, 2013
    Are you selling the plates?
  3. Dana Neibert
    Dana Neibert Member
    Dec 9, 2013
    35
    I was thinking about it. If more people want them, then we can make them. The only changes I would make would be to anodize it black, some of that cool cloth cable covering to cover up the wire harness and to find a smaller inline fuse holder. Here are some closer up pics of the plates. I think they would run somewhere in the neighborhood of $150 each—as you can see there is a lot of work that goes into them and each has 2 ptaps on it. Also the battery monitor and fuses are a must. There are two different plates—one for the gimbal and one for the top handle. If people are interested, just leave a note on this post. If we get enough interest, we could do a run.
  4. pedro faerstein
    Feb 5, 2014
    31
    I'd buy one or two.
  5. Phil Planta
    Oct 17, 2013
    one or two as well
  6. Gary Haynes
  7. Philipp Meier
    Philipp Meier Member
    Sep 6, 2013
    31
    Are you powering your camera with these batteries as well? I have a Blackmagic 4k camera and am trying out how to power the camera while on the movi. Giving me a headache.
  8. Dana Neibert
    Dana Neibert Member
    Dec 9, 2013
    35
    No, but it would probably be pretty easy to do so. Looks like the BMCC takes 12-30V which the Movi battery outputs 14-15 so it should work just fine. Just figure out what connector the BMCC uses and wire it up.
  9. Philipp Meier
    Sep 6, 2013
    31
    How long do you think one of those batteries would power up the Blackmagic? How do you power your camera on the rig?
  10. Philipp Meier
    Sep 6, 2013
    31
    Also, I'd really like to buy a pair of these. Have you decided yet if you're going to have a run?
  11. Dana Neibert
    Dana Neibert Member
    Dec 9, 2013
    35
    Doesn't look good. With just a few plates to make it wouldn't be feasible to send to production.
  12. Sean Harris
    Sean Harris New Member
    Nov 20, 2013
    21
    I would buy two
  13. Mike King
    Mike King Member
    Nov 5, 2013
    32
    I would buy two.
  14. Philipp Meier
    Sep 6, 2013
    31
    I would buy two.
  15. bevan goldswain
    Oct 16, 2013
    68
    18
  16. mike c. edwards
    mike c. edwards New Member
    Jan 19, 2014
    I as well would buy one set (top and bottom version)
  17. Philipp Meier
    Sep 6, 2013
    31
    Dana, what do you think? Would you run a batch for us? :)
  18. bevan goldswain
    Oct 16, 2013
    68
    18
    Hi everyone.
    I am going to go ahead and get this made up myself. I have spoken to a few specialist cable manufacturers and am awaiting quotations from them.
    I am making the battery plate out of carbon fibre, it will connect to the movi accessory bracket.
    Before I go ahead I wanted to hear some opinions on what people think of the following idea:
    Lipo battery mount going from jst - 3X dtaps. (to mount on top crossbar)
    Super flexible d-tap - 2 pin lemo to power FF (long enough to go from top crossbar down to FF, 80 CM long enough?)
    essentially 1 battery to power them all.
    Questions:
    1: will 1 lipo handle all 3 accessories, redrock FF, Paralinx,SmallHD ?
    2: is it worth trying making up a super flexi cable to power the FF? Or is it a better idea to put a second lipo on the gimbal and have one less hanging cable?
    It would be good to get an idea of how many people would be interested in a custom carbon fibre battery mount.
    Steve Thathiah and Kyler Zee like this.
  19. Kyler Zee
    Kyler Zee New Member
    Nov 1, 2013
    13
    I'd definitely be interested in a carbon fiber battery plate
  20. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    add me in too!
