Custom M5 Channel Mapping DX8
Discussion in 'MōVI M5' started by Dave Halton, Feb 6, 2016.
  1. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    Hi
    Sorry if this has been covered but I am new to Movi settings and being a brit I have some quirky requirements for just what the RC does.
    Basically I want the pan on the
    Rudder
    Pan Rate - on Throttle
    Tilt - on elevator
    Tilt rate - on AUX 3
    Roll on Aileron
    What would the numbers be?
    I have seen the chart but would appreciate a bit of help till I get my head round it.
    Dave
  2. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    Sorted just cant seem to get remote tilt rate working on R Knob
  3. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    Is there PRINT friendly instructions anywhere?
  4. Angus Benson-Blair
    Jan 23, 2013
    148
    25
    Dave, give me a buzz tomorrow.
  5. Andy Johnson-Laird
    10,358
    1,161
    And come back on the forum if Angus can't get it sorted for you (my money's on the fact that he will!)
  6. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    Forgot to ask about shutter control. I am doing this with AR8000 at the moment but is there another way?
    Am I just being dumb? I see settings in App but don't know where any trigger cable would be plugged in.
  7. Angus Benson-Blair
    Jan 23, 2013
    148
    25
    Dave, the shutter trigger is normally plugged into the Aux port on the Movi. Another way to do this is to bind your AR8000 with its satellite, then rebind the AR8000 with another satellite. What you now do is plug one of those satellites into the Movi as before and then you plug in a male to male servo cable into the SBus port and into the AR8000 (which has the other satellite plugged in) purely to provide power to the AR8000. You can then use one of the channels not being used by the Movi to trigger the shutter.
  8. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    Yep gone down the AR8000 root as I may stick a strobe on its arse that I can switch. Just wondered where the AUX port is! Cant see it in destructions!
  9. Gary Haynes
    Ah Dave, what a way with words you have you bloody bloke...:) You probably had an inferior desecrator do your home decor shopping....
  10. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    Probably! But which page shows where the AUX port is?
