CS8 and RED camera
Discussion in 'Cinestar 8' started by Johan Schenning, Jul 2, 2012.
  1. Johan Schenning
    Johan Schenning New Member
    Jul 2, 2012
    14
    I'm building a CS8 that will carry a RED camera. Please give me some information what motors and props I should use. I also heard a rumour that there was a new CS8 coming specially made for a RED...
    Regards
    Johan
  2. Ed Tan
    Ed Tan Distributor
    40
    Hey Johan,
    Our CS8 currently carries an EPIC for jobs.
    We used to use the AXI 4120, but found them too heavy....
    Now we are on KW8 with 14x5 XOAR Props.
    But we run 4 x 5S 5000mAh packs mounted on the booms with custom CF battery plates.
  3. Benjamin Rowland
    88
    Ed, we're looking at upgrading our motors in order to fly an Epic, do you think the KW8 motors are the best way to go right now? Do you have any sample footage? I'd love to see it.
  4. Ed Tan
    Ed Tan Distributor
    40
    Hey Benjamin,
    I dont know if the KW8s are the best, honestly i am still exploring, i just found the KW8s to be a whole lot better compared to the AXI 4120 in terms of weight and performance.
    I am still looking for a better alternative..
    i dont have much sample footages per se, we dont get to fly the epic very often, these days its always the 5D.
    but there are some EPIC shots in this TVC we helped produce, we provide the Aerials, combination of actual helis and cinestar, mix of EPIC shots and 5D shots.
    KnightDesignDev likes this.
  5. Benjamin Rowland
    88
    That's quite a commercial! Thanks for the info on the motors - let us know if you find something you prefer over the KW8s. I've seen a few other folks praise those motors - I'll take a look at them.
  6. nicnaimless
    nicnaimless New Member
    Jul 5, 2012
    10
    I'm in the same hunt for motors and prop combo. I was considering the RCTiger motors like the MT3515 or the MT2826-10s. Can you share your AUW with the 4 lipos and the RED Epic? Thanks in advance
  7. Johan Schenning
    Jul 2, 2012
    14
    Have anyone tested AXI 2826/12?
    /Johan
  8. Justin John
    Justin John Member
    54
    10
    I noticed that nobody is using the side handle when flying the red? Are you using a lipo to power the camera then?
  9. Justin John
    Justin John Member
    54
    10
    We have the 2820 / 14 setup on our DJI wookong CS8 combo and it works nicely with our red camera test weight. Blades make the most difference. apc 14's are key to lifting the heavy weight although with smaller weight (dslrs) the wookong likes the 12 inch APC's better. This provides much less vibrations.
  10. Ed Tan
    Ed Tan Distributor
    40
    nick...
    whats an AUW?
  11. Ed Tan
    Ed Tan Distributor
    40
    never got a chance to test those, anyone who has, do share feedback. =D
  12. Ed Tan
    Ed Tan Distributor
    40
    Hey Justin,
    I modified our battery mount.
    I am using the original RED Volt.
    What i did was take apart a RED Volt charger, removed the internals, and just soldered two leads into a LEMO for the camera.
    This way i get to mount the battery anywhere i want on the gimbal and i get to use the original batteries.
  13. Gary Haynes
    Ed
    I've exchanged emails with the KW8 folks. What are you using for the esc? MK or something else?
  14. Ed Tan
    Ed Tan Distributor
    40
    Hey Gary,
    thanks man...
    I am using Castle 50A ESCs.
    =D
  15. Gary Haynes
    Ed
    Thanks. I've heard good things about the castles. Are you running MK for flight control? If so what did you pick for IC2 converter?
    For big motors it just seems to be more cost effective to use individual ESC's over something like the Aerodron Aerodrive or Herkules boards.
    Gary
  16. nicnaimless
    Jul 5, 2012
    10
    All Up Weight. or the total weight of the machine ready to fly with all camera gear.
  17. Ed Tan
    Ed Tan Distributor
    40
    Hey Gary....
    i am using the DJI Wookong M as a FC, no need for a IC2 converter.
    i never liked the idea of an all in one board like the aerodrive, alot of our shoots are in obscure areas in forested or rural areas, i wanted a system our operators can easily troubleshoot and repair in the field.
    having 8 ESCs is damn messy looking, but for practical reasons, its easier to maintain and repair.
    =D
    Ed
  18. Daniel garate
    Daniel garate Member
    Jul 8, 2012
    38
    Hi ED
    im new to this forum and ive been reading this post, im also planning to build a Heavy lifter for epic or fs700,
    can you tell wich castle 50amp are you using?
    the ICE 50 amp or
    the ICE LITE 50 amp??
    and have you update any firmware on them? or just using them stock setting..
    thanks for your help
    daniel.
  19. Ed Tan
    Ed Tan Distributor
    40
    Hey Daniel...
    We are using the ICE LITE 50A, there is a multi rotor firmware update of sorts from Castle to make the ESCs capable for multi rotor use.
    Make sure you get that done and you are all set.
    We use Castle Link to update firmwares, configure and program the ESCs. pretty nifty and convenient, just have to program one ESC, save the setting files and then upload the same onto the rest of the ESCs.
    http://www.castlecreations.com/downloads.html
  20. Daniel garate
    Jul 8, 2012
    38
    Thanks very much for your help and advice....
    ill give it a try soon,
    thanks
    daniel
    Ed Tan likes this.
