Hi everyone I had a crash with my drone. It fell from five meters high to the ground (soil and grass). At first glance I thought it was ok but when I power up the Movi, the 3 green led lit once and then nothing happens. 3 cables where cut (1 of the yaw motor, 2 from the main electronic) in the protective woven black tube, so I soldered them. I tried once again to power the Movi but for the same result : the 3 leds lit and then nothing. The Movi can still connect to the freefly configurator. When I move each axis it's shown on the graphs. Appart from thoses 3 cables, the top plastic part of the electronic box received a shock (see in the pictures). Any idea? Someone had such a problem already? Is there a possibility to reset everything? Thanks in advance for your precious help. Nicolas
Nicolas I'd suggest opening a ticket with support@freeflysystems.com. At a minimum I would suggest you get new cables.
