If you own more than one Moment lens, have you purchased a counterweight for each lens, or do you have one counterweight, changing the settings each time you change lenses? If the latter, have you worked out a way to mark the settings for each lens on the counterweight? Thanks
I just write on the weights using a fine point Sharpie -- not a completely permanent solution, but there's enough "key" on the weights that the ink doesn't just rub off. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limitâ„¢ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
