I posted this into the power forums with no replies, so I thought I would try it here. Is there a way to power the Movi Controller thru AC power? Most of my set ups are on a crane with an operating desk set up so I will always have power available. If so, what do you use? Thanks
Hi Robert, When I first received my controller, I was still awaiting my V-lock Batteries, so I initially powered the Controller via the USB port. on Page 4 of the Movi Controller user guide, you'll see the power input options include the USB port, so basically you just need a USB to USB cable, plug one end into the USB port on your Movi Controller, and the other end into a plug (even an apple charger plug works) and you're good to go. All that said, I believe that doing it this way means that you cannot power a monitor or anything else through the Controller.
