Controller and messed up focus wheel
Discussion in 'MōVI Controller' started by Frank-Michael Krause, Nov 25, 2022.
  1. Frank-Michael Krause
    May 29, 2013
    29
    Hi there,
    For reference I made a clip:
    https://www.k-arts.de/FTP/Video/ControllerFokus.mp4
    i recieved a brand new controller.
    The problem is:
    I turn the fokus wheel continously in one direction. As you can see in the clip, the controller display starts at 50,9% goes down to 0% and then 99,9% stays there for a second and than goes down to 68.6%. When it hits the 99,9% mark the Fokus wheel rushes back to that position.and goes down again,
    Zeiss CP.2
    RedRock Torque Motor. (The old one)
    Can I zero the focus wheel as well like the joystick?
    thank you
  2. Bryan Edmonds
    Jul 3, 2014
    254
    126
    I see that you reached out to Support as well, but figured out the issue before we could respond!
    Would you mind posting your solution here, to help other folks on the forum?
  3. Frank-Michael Krause
    May 29, 2013
    29
    Solution:
    Focus wheel endpoints acually CAN be calibrated to Zero and 100%
    For the:
    Right EndPoint -- User 3 Switch --> UP
    then
    Menu: TX Config --> TX Actions --> Calibrate --> Menu Set for saving
    Left EndPoint -- User 3 Switch --> DOWN
    then
    this information can be found in the manual on page 30. For some reason I only found calibration for the Joystick!
    have a good one
    Michael
