Connecting radian to MK FC
Discussion in 'Radian' started by Peter Eriksson, Jan 14, 2013.
  1. Peter Eriksson
    Jan 10, 2013
    30
    I have my radian on a 2 axis gimbal and i only run solo operation. I have connected BEC power to port 1 on roll and on to Port 1 on Tilt. On the tilt (port 1) i have Pwm input from MK FC on a switch to be able to adjust tilt angle.
    I have no mode sw, so i guess it is always enabled in slew and stabilize?
    It is working great but sometimes my tilt goes wandering of without me doing any input, it is often when i forget to put the sw back in "middle" mode and leave it in the position where i want the gimbal to level out.
    Is it so that after a period of time of no movement but with slew input the radians goes to some default state, and this is what i´m seeing?
    Peter you didn't say what radio setup you are using. I ran out of switches on my MX-20 and put the mode on a rotary switch. Works fine. All the way counterclockwise is off, middle is mode 1, clockwise to the right is mode 2.
  3. Andy Johnson-Laird
    10,369
    Hi Peter:
    You might want to connect up the Radian software to the tilt sensor, click Connect and Read, just so you can double check what the Mode is defaulting to -- and whether it's happily staying in that default or twitching into some other mode.
    Can you also confirm that you've updated to firmware 1.03 as it fixes some known issues with jitter on PWM signals?
  4. Peter Eriksson
    Jan 10, 2013
    30
    Gary,
    Im using the mx20 as you are, thanks for the tip
  5. Peter Eriksson
    Jan 10, 2013
    30
    And how can i force it to be i a certain mode without modecontrol?
    I bought my radians from kopterworx one week ago, maybe they are updated......how can i check wich version i have?
  6. Sedric "Zellevision" Sari
    Sep 21, 2012
    87
    Peter, call me tomorrow and I'll explain to you in swedish ;)
    0704419911
  7. Andy Johnson-Laird
    10,369
    Peter: Gör vad Sedric säger - han talar svenska mycket väl. :D
  8. Sedric "Zellevision" Sari
    Sep 21, 2012
    87
    :) u swede wannabe
  9. Peter Eriksson
    Jan 10, 2013
    30
    lol
    Härliga bananer jag ringer :)
  10. Andy Johnson-Laird
    10,369
    It's the Swedish night club scene that got me started. :)
