i just purchased the connex HD and i am trying to connect it to my Movi M5 battery. Is there a splitter i can buy for this or do anyone know how to fix this solution.
I don't have a Connex, but from the specs it looks like you'd need to make a splitter by hacking up one of these. Voltage is spec'd at 3S-6S so that shouldn't be an issue. Freefly do not recommend running anything else off the MōVI battery, but (don't tell anybody) I do it all the time. Just have to be very careful. http://connex.amimon.com/air-unit-power-cable
There is a splitter specifically for that, in fact, they included two of them when they shipped my ALTA and MOVI. Here is the link where you can buy it: http://www.e-fliterc.com/Search/Default.aspx?SearchTerm=EFLA228
Terry, it's worth putting another battery on for the Connex, it fair rips through the Movi battery but if you run two then you're good for a couple of hours.
This is brilliant. Do you happen to know if this could then power a Small HD monitor or other accessory?
