I have an issue with the configurator on my new Nexus 7. When I try to load a saved program the app crashes, anyone got a solution for this? Regards
That sounds like something that you need to open up a support ticket with Freefly for, Ricard: email to support@freeflysystems.com Can you also clarify what you mean when you say, "saved program" -- do you mean a previously saved *configuration*? Thanks Andy
Correct, If I save a program and try to load it the app crashes. It´s a pretty big issue since I have to write down all the settings and manually enter them to "switch" between settings. I will send them an email at support.
OK. That's technically not called saving a "program" -- it's saving and loading a configuration file -- and I don't point this out to be pedantic -- I just didn't want the FF support guys to misunderstand the problem that you're having. Andy.
