Hello, It is possible to setup WI-FI adapter and a Mimic receiver together ? How can I do this ? Thank you
Romain welcome to the forums. Would you be kind enough to change your user name to your real first name and last name, please? The reasons for this (and how to do it) are explained here: http://forum.freeflysystems.com/index.php?threads/real-names.497/.
Hi Romain, Did you figure it out? I am wondering the same thing. Can you setup WI-FI adapter and a Mimic receiver together?
Romain, doing this from memory but I don't think they can be used at the same time. Both use the small 5 pin cable as I recall and you can only run one at a time since there is only one 5 pin port. Might be wrong but ....
You cannot plug in both at the same time, as there is only one 5-Pin port. You can only use one at a time.
Any possibility that this could change with the production model? Been eyeing the Mimic for a while and I'd be disappointed if I couldn't use it as a result of the Bluetooth/iOS functionality never working out.
We would be happy to pass your request onto our engineers as a possible feature update. If you have any other questions, please contact us at support@freeflysystems.com
