I'm getting both Compass error and IMU error on my freefly configurator. I'm getting flashing green led's on the back of the m15. Did a wire come loose maybe? I'm looking around for it but if you all have some intel pls help a brotha out. thx
Marcel: Can you confirm that the M15 was as motionless as possible when you powered it up -- also are you using a fresh battery? If the answer is yes to both, and all three greens are flashing then there is an IMU error. I presume you've tried this several times the fault occurs every time? Andy.
Is this a brand new M15 that you're just bringing on-line or was it working correctly before? As you say, it sounds like there might be a loose connector -- presuming that you've checked for that and gently re-seated the connectors, it does sound like you might want to open up a support ticket by sending email to support@freeflysystems.com. Andy.
yeah, it's brand new, yesterday was it's first day in use. it was fine all day until the end of the day and the error started to pop up. i have tried to re-seat connectors.
