I would like to make a circular movement around a couple of people with the Movi Pro, what do you advise me as setting so that it is as fluid as possible. Thank you
Here's one tip: Try offsetting the Pan so that the Movi is Panned toward the inside of the circle you'll be walking. This is easily done by loosening the latch on the Toad in the Hole and panning it so the Gimbal faces inward. This will keep you from cross-stepping while you walk. You can walk forward in a circle instead of crossing your feet as you go, and will help your shot be smoother.
