Cinetape mount
Discussion in 'MōVI Pro' started by Charlie Beyer, Jul 10, 2017.
  1. Charlie Beyer
    Charlie Beyer Member
    Nov 12, 2013
    70
    Does anybody have any leads on a good mount for the cinetape to the top crossbar of the movi Pro? I've removed all the adjustable screws and stuff and I have it Velcroed and bongo tied to a pop n lock but it's not really stiff enough.
  2. Charlie Beyer
    Nov 12, 2013
    70
    I should have said it's the cinetape horns that I'm talking about. The brain part I've got a good spot for.
  3. Graham Futerfas
    1,221
    239
    I can't post photos to the Forum at the moment, unfortunately, but I had come up with a way to create Dual-Lock velcro mounts on the top cage crossbar before there were pop-n-locks. They cost about $1 at the hardware store.
    Imagine a large flat washer on the top, and another one below the top cage rails, and a small #8 bolt and nut to clamp them together. The bolt runs between the two rails on the top of the cage. I put Dual-Lock Velcro on the top washer, and you can velcro anything to it. For Cinetape, you might consider a small L-bracket on top with Dual Lock.
    If they get the Forum fixed for uploading files, I can send some pics.
  4. Charlie Beyer
    Nov 12, 2013
    70
    That's given me an idea along the lines of the bolt and washer. I had done something similar before on the M10 for a cintape off the bottom bars. If I figure out a good way, I'll try and upload any photos I have.
  5. Deniz Ozgoren
    Deniz Ozgoren Support Mage
    Dec 17, 2015
    273
    84
    Dropbox link :)
    Graham Futerfas likes this.
  6. Graham Futerfas
    1,221
    239
    Good call, Deniz. Photo Uploads are (mostly) working again as of this morning. :)
    Here are the little mounts I made out of washers and bolts and Dual-Lock Velcro:
  7. Andy Johnson-Laird
    10,366
    It's fixed, Graham. :)
  8. Graham Futerfas
    1,221
    239
    Thanks Andy! The 2x4 and a hammer worked, then? :)
  9. Andy Johnson-Laird
    10,366
    All done with the power of email and Neil's assistance (Neil is a forum god, I am merely pond-scum :) )
