Hey guys! I recently purchased a MoVI Pro and ended up going with the Cinemilled pro ring, Cinemilled Movi universal plate, and a Cinemilled Ronin 2 plate in place of the Movi kit. Cinemilled recommended I get the Ronin plate in place of the Toad in the Hole as it cheaper and more secure. The issue I am having is the CM Movi Plate mounts to the Movi at an angle rather than straight on. The is causing the Movi to think it is centered but it is aimed in the direction of the plate. This is an easy fix If I had the TITH as it can rotate for centering, however with the ronin plate, it is stuck in this angled position. I have included pictures to better explain. My question is, is anyone using this setup and if so, how have you guys corrected the centering? Is there a way to recalibrate the center position within the Movi? Thanks!
There’s a Pan Trim adjustment in the General settings of the app. That might be a fix for you, although it sounds less than ideal.
