I've had the MOVI Cinema Robot I just bought on a wall charge overnight for the past two nights and still cannot get the unit to turn on. The red light blinks when it’s charging. Any suggestions on what’s going on and what to do about this?
It sounds like there's an issue with the charger so I'd recommend you do two things: Try removing and reinserting the batteries and try charging one more time -- just a slight chance that that might clean the contacts and fix the problems. Otherwise I'm afraid you'll need to open up a ticket by sending an email to Freefly Support (support@freeflysystems.com). Hope this helps Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
