Changing channel on Lawmate TX? What's the default channel?
Discussion in 'Electronics' started by Ben Freedman, Feb 18, 2013.
  1. Ben Freedman
    Ben Freedman Member
    Jan 11, 2013
    119
    Howdy...
    I have the lawmate transmitter/receiver from QC.
    The lawmate is supposed to have 8 channels, I believe, however the dip switches where you select the channel is completely covered by hot glue of some sort. I can't see what channel it's on, nor can I change the channel. I have tried to get some the of glue away with a toothpick, but I can't get very deep and am afraid of hurting the PCB.
    The receiver can be set to 8 different channels, and seems to receive video on 3 or 4 different channels, but I'm not sure if this is just bleed, or what channel it is supposed to be set to.
    Question: What is the a 'default' channel that the lawmate is set to, and should I be able to easily change that?
    Thanks!
    Best,
    Ben
    Benjamin Freedman
    PrimeImage Media
    480-399-0000 - direct
    480-240-9270 - office
    866-549-6051 - fax
    ben@PrimeImageMedia.com
    www.PrimeImageMedia.com
  2. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    HI Ben,
    They are locked in the USA to 1280MHZ
    Tabb
  3. Ben Freedman
    Ben Freedman Member
    Jan 11, 2013
    119
    So any idea which channel is that on the receiver?
    ...and why does QC offer this as "• 8 channels DIP switch selectable."
    Best,
    Ben
  4. Ben Freedman
    Ben Freedman Member
    Jan 11, 2013
    119
    OK. Think I found it...
    It's channel 8 on the TX, and the receiver needs to be set to Bank "B" channel 8....
    Man...they don't like to make this stuff easy :)
    B.
  5. Andy Johnson-Laird
    10,369
    I believe in Canada they can operate on more frequencies -- just in case you have any friends up there? ;)
  6. Brad McGiveron
    Brad McGiveron Active Member
    Jul 7, 2012
    396
    65
    Yup and unless things have changed, technically in both countries its only legal to operate with a Ham radio license... o_O
  7. Dave King
    Dave King Well-Known Member
    Dec 24, 2012
    2,711
    311
    Ben I just bought one and will be in this position. How do you set to bank B?
