CCW motors are hotter on CS8
Discussion in 'Cinestar Misc' started by Josh Allen, Jan 20, 2014.
  1. Josh Allen
    Josh Allen New Member
    Mar 1, 2013
    What could be the reason for this, what did I miss?
    CW are cold as ice, but all CCW are quite hot.
    Using DJI Wookong and T-motor CF 15" props.
    In manual mode CS8 is flying straight and all trims are set to 0
  2. Gary McCready
    Gary McCready Active Member
    Oct 26, 2012
    284
    42
    I had a similar problem: (but with MK)
    One motor was tilted or twisted at a slight angle on the arm. I have round CF arms (CS6), so the one motor was slightly off, and with the tilt it creates a yaw force. The other motors have to try to compensate for it i guess, and so all the other counter rotating motors/Esc became hot. It was motor one (1) that was tilted/twisted, so the 2,4, and 6 Esc became hot.
    Eyeballing it, I couldn't hardly tell, but I got out a level, straightened it so that the motor was perfectly perpendicular to the ground (again), and that did the trick.
  3. Josh Allen
    Mar 1, 2013
    I aligned all the motors again and it helped! Now I also have less total Amp draw.
    Thanks!
  4. Gary McCready
    Oct 26, 2012
    284
    42
    You are welcome! Took me awhile to figure it out, but after I did it made perfect sense. I know alot of guys just eyeball the motors, but obviously that didn't work for me. The one motor that was twisted had to be only 5-7 degrees. But for the other motors to compensate (not being twisted in the other direction) they had to work really hard.
