CANT UPDATE CONTROLLER
Discussion in 'MōVI Controller' started by Diego Comendador, Jun 20, 2019.
  1. Diego Comendador
    Diego Comendador New Member
    Oct 23, 2013
    I dont know why but when i start the updater cant see the COM port.... how can i do it???
    Please help!
    10,347
    1,159
    Diego:
    Can you confirm that you're using a USB cable that is not just a charging cable (there are some cables out there that lack the data pin connections) and that you're plugged into the lower USB port on the Movi Controller -- the upper port will not function for firmware updates.
    If you are using the lower port and you're sure that USB cable is a data + power cable, then go into the Windows Device Manager and, using some other USB device, eg. an external disk, see if you see the additional device appear when you plug it into the PC's USB port. If that doesn't happen, then the problem is with Windows (EDIT: Try powering the PC down to cold and then restarting it...)
    Hope this helps
    Graham Futerfas likes this.
