Canon 1DX/Movi5....Compatible?
Discussion in 'MōVI M5' started by Jim Wilson, Apr 6, 2014.
  1. Jim Wilson
    Jim Wilson New Member
    Apr 5, 2013
    I shoot Canon 1Dx and Nikon D800 bodies. The 1DX with a 24-70II lens is under five pounds, not by much though. Any opinion on how the Movi 5 might work with those cameras?
  2. Josh Lambeth
    1,315
    216
    It won't work due to the camera tray not being big enough to fit the 1D cameras.
    Josh
  3. Jim Wilson
    Apr 5, 2013
    Thanks Josh. That adds another 10K to the equation :(
  4. Josh Lambeth
    1,315
    216
    Yup, i'm in the same boat.
  5. Mike Vickers
    Mike Vickers New Member
    Oct 18, 2013
    25
    I haven't tested this myself but I've seen one video where the top bar of the M5 was taken off to fit a Canon C100. The same may work for the 1D models. You will loose a bit of stability but it should still work ok.
  6. Steve Maller
    You’ll be better off with the D800, but even with that one, you’ll want to use a light-ish lens.
  7. MIke Magee
    MIke Magee Active Member
    422
    103
    There is a possibility that it might work. Here's the 1D with a 16-35 on the M5. Top bracket off but still pretty stable.
    Michael McVay likes this.
  8. Dylan Law
    Dylan Law Member
    Nov 7, 2013
    48
    11
    We have had the 1DC and C100 on the M5 with no problems what so ever. Just take off the top support and balance correctly and you are good to go.
  9. Peter Scudner
    Peter Scudner New Member
    Nov 30, 2013
    Dylan - I'm interested in flying a C100. Glad to see you did and the guys at Abel Cine did too. Any issues? What lenses are you using? I know some say that the cage isn't stable without the top bar or the motors work too hard. Your thoughts? Any pictures? Thanks. Pete
  10. Dylan Law
    Dylan Law Member
    Nov 7, 2013
    48
    11
    Hi Peter - I have had no issues with a C100 on the M5. It is as simple as removing the top bar and balancing correctly. It all comes down to getting the right balance dialed in and the M5 with a C100 flies like a dream.
  11. Mike Sutton
    Mike Sutton Member
    Apr 23, 2013
    76
    19
    Its works fine with 1Dc or 1Dx you just are not going to get a wireless FF on there with it.
  12. Nicolas T
    Nicolas T Member
    Jan 15, 2014
    163
    23
    Surely they must have added the top support for a reason. I was under the impression it partly had to do with only having one screw for most DSLR.s so the the camera in theory can twist in the position. I use Really Right Stuff L-Plate with my camera but it has too much vertical distance when put on the Movi. In theory I could mount a RRS clamp to the provided camera plate with two screws and then have an anti-twist. How are you handling this with the bigger cameras ?
  13. Keith Soucy
    Keith Soucy New Member
    Apr 17, 2014
    Hey Dylan, what stiffness settings have you been using for the C100? I'm using the 50mm1.4 and 24mm, and so far so good. Have you played with any other lenses that work better? the 16/35 is a tad heavy, but I have not messed with stiffness.
  14. Dylan Law
    Dylan Law Member
    Nov 7, 2013
    48
    11
    Hey Keith,
    I find myself running at around 20's for over all stiffness with some small adjustments here and there. Have no fear with that lens. if things are balanced perfectly you will be more than fine. These units are sneaky and if balanced right can handle more then you would think. Hope all is well with you.
    The fun part is working with the M10 and building up a full EPIC rig.
  15. AlexBahena
    AlexBahena New Member
    Apr 4, 2014
    I have a Nikon D800 with a 14-24 lens with no issues. I'll probably go with a prime later but it works fine with the 14-24 and I wouldn't say it's the lightest thing on earth, but it's under the weight limit. I did have to remove my quick release bracket.
  16. David Lavery
    David Lavery New Member
    Apr 4, 2014
    I've been using d800 with my Nikor 16mm prime. But also with my Zeiss primes, that are pretty heavy.
  17. AlexBahena
    Apr 4, 2014
