Can MIMIC be charged via COM port?
Discussion in 'MIMIC' started by Iacopo Boccalari, Mar 14, 2019.
  1. Iacopo Boccalari
    Iacopo Boccalari New Member
    Jul 16, 2014
    I'm working with the Movi API and designing a little PCB that's connected to the MIMIC via COM1 port.
    My pcb draws very little current and I can easily power it with the +5v supplied by the COM 1 port.
    Now I'm wondering if I can do the opposite and actually charge the MIMIC supplying it with 5v on that same port.
    I would, of course, power it with a regulated supply; is this doable? Is it ok to do? Do I run any risk?
    Thanks!
    Icopo: I seem to recall that the answer is no, there's not enough current available -- but that could well be my failing memory. You might want to open up a ticket with Freefly Support and the best way of doing that is to head over to https://freeflysystems.com/contact
