Bricked after Firmware Update?
Discussion in 'Movi Beta App' started by Wes Hopkins, Aug 7, 2018.
  1. Wes Hopkins
    Wes Hopkins New Member
    Jul 30, 2018
    Hi All,
    Is anyone experiencing issues with their unit after applying the firmware update in the 1.2.2 B133 app?
    I'm now stuck in the following cycle:
    - The unit always starts in red blinking error state
    - The app indicates that a newer firmware is available
    - Apply firmware
    - App eventually says "wait for purple led flash to finish", (which it does - the LED goes solid red, and stays that way.)
    - Neither app nor unit does anything for an hour or more (safe to assume that after 2 hours it's a hung/error state)
    - Reboot movi
    - Back to red blinking state; repeat.
    Unfortunately I can't downgrade the firmware using the App Store version (it will appear to go through the firmware patching process, but the installed version doesn't change, and the unit stays stuck per loop above.)
    So.... has anyone else encountered this?
    10,358
    1,161
    I've not seen any reports of this problem, Wes -- having you opened up a ticket by sending an email to Freefly Support (support@freeflysystems.com)?
    The Ground Is The Limitâ„¢
  3. Wes Hopkins
    Jul 30, 2018
    I did, thanks Andy. It looks like it's been diagnosed as a hardware issue, and can't be fixed remotely. It will have to be replaced, and they're sorting me out now. Very impressed with the assistance.
    John Chu likes this.
    10,358
    1,161
    Hi Wes:
    Bummer.....sorry to hear that you have to return it, but FF's technical support is (at least in my experience) very good.
