Hello everyone, I'm having problem to load the latest new firmware. In the bootloader, I tried to load the firmware file, but when I located the file, in the bootloader status bar, it says invalid data format on input line 1. I can't program the new firmware. Help please!!! Best Regards, Rui Ma
Rui did you unzip the files when you installed or are you trying to run them from within the Zip file? Some folks have tried to run from within the Zip and that doesn't work.
Hi Rui: As I mentioned in the Conversation reply, can you confirm that you have Windows set to English language. This problem has been seen in the past if you have the Localization settings set to any language other than English. Sorry about that. It's an issue with the double-byte character sets and the way that Windows handles reading binary files. Andy.
