[Setup cannot continue because some system files are out of date on your system. Click OK if you would like setup to update these files ofr you now. You will need to restart Windows before you can run setup again. Click cancel to exit setup without updating system files.] Click OK and reboot. And re-install ... Click OK and reboot. Just repeat. win-xp sp3 (32bit) - Korea
I did a Google search for you using this text string: Setup cannot continue because some system files are out of date on your system This might be the most relevant: http://support.microsoft.com/kb/831491 Note the Resolution section. There are many other search hits that you may wish to examine. Hope this helps. Andy.
Thank you your answer. Gave the contents could not be resolved. Systemfile of damage rather have to reinstall Windows XP. Is going well now. Expected.
