blackjack + 360 roll + gamepad = weird controls when at 90°
Discussion in 'MōVI Pro' started by Iacopo Boccalari, Feb 8, 2019.
  1. Iacopo Boccalari
    Iacopo Boccalari New Member
    Jul 16, 2014
    I've just bought a Movi Pro and I'm using a frsky Taranis (+ sbus receiver) connected to it.
    I'd like to control the roll axis the way shown in this video I hope this feature is not limited to movi controller only
  2. Graham Futerfas
    1,213
    237
  3. Iacopo Boccalari
    Jul 16, 2014
    Thanks Graham for your reply!
    I bought a playstation ds4 controller and everything seemed to work just fine, then I realised I'm having a problem with controlling pan when in portrait orientation.
    The movi roll is set to 360 mode + snap, while tilt is set to majestic, ds4 controller connected to mimic and set to dual mode.
    To avoid gimbal lock I rotate the movi 90 degrees while I give it some roll input via the controller, so far so good.
    The movi is now in a state where the camera is in portrait mode and stabilised on each axis, if I give it a pan input, the camera pans, but if I give it a tilt input the camera pans as well, instead of tilting.
    If I keep on rolling so that the camera is upside down, the controls are back to normal.
    Is there anything wrong with my setup?
  4. Iacopo Boccalari
    Jul 16, 2014
    here is a quick video showing the problem whith the movi mounted at a 90° angle
