Our customer had a problem with his MK Hexa XL and it crashed. He said that one engine got crazy during flight , Anderson disassembled the Hexa and he found that the BL Controller form engine 1 was burned. This was probably the reason for the crash. Now Anderson is going to REPLACE the BL Control , so it's a little tricky but it is a good experience for those who one day need to do the same. BL Control Changing in MK Board Tips (15 min 41 sec)
Hi Thiago from Drones for You and Anderson from Drones for You. Thanks for yet another tech tip video. I just love em'. They are informative, and I find them highly entertaining. Don't change a thing! Keep up the great work. Dave
Thiago & Anderson, Good video. One thing I noticed is that the ESCs and caps on 2-6 appear to be factory installed. The one cap remaining on #1 was not factory installed. My guess is that the customer had previously done work on ESC #1 and his job was not done properly which caused the crash. Also, the capacitors are glued down to the ESC with high-temp adhesive further preventing the caps coming loose b/c of high frequency vibration. Greetings, Adam
