Hey guys... I've searched high and low for info on this sequence of led flashes on my #2 BL. All the other motors start and run normal. Even in MKTOOLS I cannot get Motor 2 to respond. I see in the MK WIKI that the 2 flashing red led's indicate a Phase B issue. On start up sequence the motor does in fact chirp and the prop moves as all the others do. When you go to start it simply does not. I was wondering if anyone knows if there is an end user procedure to rectify this issue... or do I need yet another BL ... Hadn't had an issue with it at all prior. Added the upgraded ACC 2.2 board ... flashed the new firmware for the FC and the Navi board. Aligned the compass and viola..thats when I noticed there was an issue with #7 not starting. Thanks for your help!!
Hello Scott, You could try and rectifying the error via software update to the BlCtrl #7. Info on the procedure is here: http://www.mikrokopter.de/ucwiki/So...l.2BAC8-TerminalWindow-SoftwareUpdate.BL-Ctrl Greetings, Adam
So in my original thread ( I have made the change now) I said it was BL2 and motor 7 ... dohhhh... it's BL2 and motor 2 sorry for the confusion.
