Binding process
Discussion in 'WEDGE' started by Derek Cooper, Jun 28, 2015.
  1. Derek Cooper
    Derek Cooper Active Member
    Apr 28, 2014
    527
    34
    Hey Gang,
    Looking to acquire a WEDGE - how do we bind to the WEDGE from the Movi Controller?
    I'm assuming we set the WEDGE to the same channel as the Movi and the Controller will bind to both? Doesn't mention the binding process in the manual unless I missed it, which is entirely possible! o_O
    Derek
  2. Derek Cooper
    Apr 28, 2014
    527
    34
    Love finding my own answers! LOL
  3. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    Derek, it's not even clear on the video.
    I put them to the same channel and bind one by one afterwards. It works this way. If the channels are different it doesn't work.
  4. Derek Cooper
    Apr 28, 2014
    527
    34
    Perfect - I'll let you know if I have any problems later this week when our WEDGE is slated to arrive.
    How do you like your WEDGE?
  5. Ozkan Erden
    Aug 3, 2012
    678
    131
    Pretty slick setup and so lightweight. No regrets buying it; loving it.
  6. Derek Cooper
    Apr 28, 2014
    527
    34
    Excellent - what I wanted to hear.
  7. Derek Cooper
    Apr 28, 2014
    527
    34
    We got hung-up on the bind process for some time - then Bryan at FF told me the process is a bit different from binding to the Movi.
    As we know, to bind to the Movi you press and hold the bind button for 2-3 seconds. The light starts blinking red fast, then when it goes slow blink, you start the bind process on the Controller - easy.
    With the WEDGE, and this is where we were going wrong, you actually start the bind process on the Controller right after pushing the bind button on the WEDGE. Don't wait for slow blinks - it'll never bind.
  8. Aleksandar Bracinac
    Aleksandar Bracinac New Member
    Jun 28, 2015
    When I bought Wedge, binding was successful at the first time and worked at glance. After upgrading firmware to 1.0.1. can't bind Wedge anymore. Tried a dozens of times. It shows green, but controller says "Freefly wedge is not connected..." or something like that.
    Any ideas?
  9. Derek Cooper
    Apr 28, 2014
    527
    34
    Describe your activation procedure. When it shows green, is it solid green, or solid, then flash, then solid? When you push the bind on the WEDGE, do you immediately push bind on the Movi Controller? That is the correct way to bind - push the bind button on the WEDGE and immediately push the bind on the Movi Controller - do not wait for a slow red flash on the WEDGE. It's different than binding to the Movi.
  10. Aleksandar Bracinac
    Jun 28, 2015
    Yes, I'm doing binding with pushing button on the Wedge and immidiately on Controller. After "binding" it's solid green than flash, than solid. Some times it's fails and it's red. Anyway, I can't get it to work anymore.
  11. Aleksandar Bracinac
    Jun 28, 2015
    Solved!
    From some reason I have to turn off and on the Controller after bind process is finished. If not, Wedge will not work.
  12. Andy Johnson-Laird
    Nice find, Aleksandar. I have no idea why this should be necessary, but it sounds like it falls in to the class of computer-related mysteries that are solved by power-cycling the computer.
    Aleksandar Bracinac likes this.
