Battery charging and safety,timer
Discussion in 'MōVI M5' started by David Cooper, Jun 23, 2014.
  1. David Cooper
    David Cooper Member
    Mar 22, 2014
    30
    Being new to LiPo batteries, wondering if there is a simple timer use to plug in the charger and have it turn off in an hour. I have already left it for half a day charging and have heard you really need to be careful with these batteries if unattended.
  2. Jason Comparetto
    Sep 23, 2013
    269
    38
    That's a great idea David. If the hazards of charging these batteries is true, then why isn't there a charger with a timer built into it?
  3. Gary Haynes
    Which charger? If it is the FF charger it will ramp down with a full charge. A household lamp timer would work if you want it to completely disconnect.
    10,369
    The Hyperion Superduo chargers have the option to set a maximum charge time -- I think the default is two hours.
  5. Janne Hoglund
    Janne Hoglund Member
    Oct 4, 2012
    364
    23
    Most other Lipo-chargers have sound alarm, I cant understand why Tabb choose to use one without it?
    Love the M5 but not the charger ;-/
  6. Mike Duval
    Mike Duval Member
    Apr 24, 2013
    66
    18
    Here is a good video about LiPo charging and safety. The sand trick is particularly impressive for squelching LiPo fires.
  7. Andy Johnson-Laird
    10,369
    WARNING: If you use an Ammo box for LiPo storage and it's airtight (as many of them are), and you have a LiPo fire, you now have a LiPo *bomb* -- the gasses given off by the burning LiPo cannot escape an Ammo box unless you drill a pressure relief hole. It will explode.
    I drill a 3/8" hole in the lid and put PVC electrician's tape on the inside and the outside of the hole so it does not present any edges. In case of a LiPo fire, the tape will just blow out and relieve the pressure.
    Why would a LiPo just lying innocently in an Ammo case ignite? Oh....perhaps if you drop the Ammo case on to concrete.....
  8. Martin Lebel
    Martin Lebel New Member
    Mar 1, 2015
    If I have a M15 and travelling with 10 lipo bat. how i could drop down the lipo bat. to the recommended 3.8 volt for travel. and how I could prevent to go under 3 volts on the rig when we are shooting.
  9. Martin Lebel
    Mar 1, 2015
    Just to make shure with the freefly charger we don't need a timer to stop the charging because the freefly charger have a auto turn off when the battery is full.
  10. Martin Lebel
    Mar 1, 2015
    or i should buy a timer to be more safe
