Anyone tried the M15 with any type of boxcamera?
Discussion in 'MōVI M15' started by Gustav Raberg, Dec 19, 2014.
  1. Gustav Raberg
    Gustav Raberg Member
    Dec 30, 2012
    101
    13
    Hello.
    We got a few request about using a broadcast camera like the Sony P1 with Canon HJ14 lens. Its a loooong setup and I'm not sure it will fit since the lens is long and heavy making the CG closer to the front.
    Anyone tested?
  2. Kurt Wallrath
    Kurt Wallrath Member
    Nov 8, 2013
    135
    21
    Hello Gustav,
    If I were you and you own an M15, you should take the M15 to them to try and make it work. The Sony P1 weighs 3.75 lbs (1.7kg) and the lens weighs 4.39 lbs (1.99kg). Since the lens weighs more, the cg is going to be somewhere over the lens so you're going to need to move the camera farther back on the MoVI. If you run out of space, you can add weights (or aks) so you don't hit the back of the roll bar.
    Good luck!
