Anyone have issues with HDMI on their WAVE?
Discussion in 'Wave Camera' started by Marcin Biegunajtys, Jan 18, 2021.
  1. Marcin Biegunajtys
    Marcin Biegunajtys New Member
    Jan 17, 2021
    Mine quit working a day ago all the sudden. I downloaded some footage and then the following day when I turned on the camera it wouldn't pick up the signal on any HDMI monitors. I can still record, but I cant see what's happening. anyone have similar issues?
    Marcin:
    Sorry to hear about the issue you're having. This forum is primarily intended for dialogue between Freefly's customers, not as a primary means of getting technical support from Freefly -- for that you need to open up a ticket with Freefly Support and the best way of doing that is to head over to https://freeflysystems.com/contact
    That said, when their workload permits, I do know that Freefly technical support will occasionally review some of the threads on the forum, but opening up a ticket really is the optimal way to get support.
    Marcin Biegunajtys likes this.
  3. Marcin Biegunajtys
    Jan 17, 2021
    got that going as well, just testing to see if anyone else is experiencing to hopefully get things back up and running asap.
    M
    If you have time, and you do get a resolution, please post again with the resolution as I'm sure other people would like to hear about it.
    Cheers
  5. PJ Mozingo
    PJ Mozingo Member
    Dec 17, 2014
    55
    My HDMI port is working good so far. I'm even using a 90 degree adapter out of the camera as well. Was the camera stored with the cable connected at all or potentially too much pressure applied to the connector at all?
  6. Javier sanchez
    Javier sanchez New Member
    Apr 8, 2021
    Lost my hdmi yesterday too, I no longer have image.
    wave run out of battery turn off and when charged back and turn on no more hdmi.
    did you fixed it? I am contacting support.
  7. Andy Johnson-Laird
    I've not seen that problem reported, Javier. Please post again when you find out what happened.
  8. Marcin Biegunajtys
    Jan 17, 2021
    I had mine replaced and was told that it was a possible issue that's being investigated. In my opinion, HDMI is extremely weak, and the placement of it is odd for holding without the possibility of snagging or damaging the port. I had the camera on my cinema robot and had all cables tucked away, but still had something happen where between moves I lost signal and that was it. I'd rather see HDSDI port so you can use lighter cables and lock in the cable proper.
  9. João Tocha
    João Tocha New Member
    Apr 5, 2021
    Hi, what cinema robot are you using? And what software do you use to control it? Is it directly connected to the wave camera?
  10. Marcin Biegunajtys
    Jan 17, 2021
    BOLT, flair software.
  11. Mieszko Socha
    Mieszko Socha New Member
    Jun 5, 2021
    Just lost HDMI out of the blue.
