Anyone had a Sony P1 camera on the Movi Pro?
Discussion in 'MōVI Pro' started by jim mundell, Apr 9, 2019.
  1. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    Hi getting some calls for broadcast client that wants to use a sony P1 camera on the Movi Pro. Curious if anyone has tried it yet. Know I've seen it on the Fox broadcast.
    The weight of the broadcast lens would be the big issue Id assume.
  2. Graham Futerfas
    1,261
    245
  3. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    Man you are one helpful human being. Thank you as always Sir. Hope you're well!
  4. Graham Futerfas
    1,261
    245
    You too, Jim. He had a good Instagram post about it a while back. It was a beast of a setup.
  5. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    Will check it out.
    Weve been going back and forth about our Ultra arm builds. Another good guy.
  6. Benjamin Granet
    Aug 31, 2015
    38
    10
    I did it a couple weeks ago as a test for a project I'm doing later on this summer.
    It work really well thanks to the Ignite accessories, tilt offset and their counterweight bracket.
    The only this is that I had to do custom cable to put the Wireless CCU controler and XLR to reduce the number of counterweight I needed.
