Any recommendations with a follow focus system - Junking RedRock Micro!
Discussion in 'MōVI Pro' started by Adam Brennan, Jan 6, 2018.
  1. Adam Brennan
    Adam Brennan Member
    Dec 29, 2013
    235
    14
    I need to find a new system for pulling focus. My redrock micro remote torque motor chatters on the lens/gear when it's on and not pulling focus. I am a bit pissed off at this and starting to realize their products are not up to par. What are some suggestions to use for pulling focus remotely and also will work on the MoviPro as a single operator?
  2. Rob Weidner
    Rob Weidner New Member
    May 13, 2017
    29
    Grab some hocus reflex and use the molex to lemo cables
  3. Alejandro Selman
    Alejandro Selman New Member
    Mar 27, 2017
    Hi Adam,
    You may need to adjust the gain on the microRemote's Basestation, and lower the torque setting to it's optimized setting which is 5. If you're running our 4.0 firmware, tap the Down button to lower the high torque setting. If you set it lower, you'll see increased smoothness.
    Please drop Support a line at support@redrockmicro.com if you continue experiencing issues with your system. They're eager to trouble shoot your system and directly assist you.
  4. Ryan Forte
    Ryan Forte Member
    Oct 5, 2015
    69
    I highly recommend the Chrosziel Magnum. I own a two handset kit with Panavision, Arri, Red & Cinetape Cables.
    An affordable starter kit is this.
    https://shop.chrosziel.de/shop/eng/kits/986/magnum-kit-2-channel-with-chrosziel-motors-cdm-100?c=309
    It has two motors.
    You should contact Timm with any questions. He is a good friend of mine. They hands down have the best Customer Service over any company I have ever delt with in this field.
    Timm Stemann
    Product Specialist Lens Control & Broadcast
    timm.stemann@chrosziel.com
    Tel: +49 89 9010910
    Mob: +49 171 423 8862
    Fax: +49 89 4470861
    www.chrosziel.com
