Alta Service Bulletin re: Motion booting re: firmware 4.0.4 and earlier
Discussion in 'Announcements' started by Andy Johnson-Laird, Jan 26, 2017.
  1. Andy Johnson-Laird
    FREEFLY ALTA SERVICE BULLETIN
    JANUARY 26, 2017
    [​IMG]
    AD17 Motion Booting in Firmware 4.0.4 and previous
    Date Released: 25-January-2017
    Subject: Motion Booting ALTA using Firmware 4.0.4 and previous
    Effectivity: All ALTA 6 and ALTA 8
    Require Action: Required
    INTRODUCTION
    This Airworthiness Directive (AD) is being issued to alert all ALTA users of a bug associated with the Motion Booting function that could prevent the machine from booting and operating successfully. Use of the Motion Booting function is not recommended for firmware versions 4.0.4 and previous. No other functions are known to be impacted by this bug.
    This AD is being issued to all ALTA 6 and ALTA 8 owners.
    BACKGROUND
    ALTA flight control firmware includes an optional function to allow the machine to be booted on a moving platform such as on a boat. This boot process is “off” by default in the ALTA App and must be selectively turned “on” to be used.
    DISCUSSION
    A bug was discovered that affects the stored gyroscope data on the Synapse flight controller. During the Motion Booting startup sequence, the ALTA could pull old or incorrect gyroscope data or may revert to estimated values rather than the stored values. As a result, the machine may exhibit out of control behavior if booted with Motion Booting on.
    The standard booting process is not affected by this bug.
    RECOMMENDATION
    Do not use the Motion Booting function available in the ALTA App v1.6 (Synapse firmware version 4.0.4) until a new firmware version has been released for public use.
    For questions regarding this Service Bulletin, please contact Freefly Support.
    Freefly Customer Support
    Email: support@freeflysystems.com
    Phone: +1 (425) 485-5500
    Hours of Operation: M-F 8am-6pm PST
    Best Regards,
    Freefly ALTA Team
