ALTA Go-Home not working
Discussion in 'ALTA' started by Adam Varadi, Nov 3, 2015.
  1. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Hy Guys,
    I have tested my alta for a few days now and everything works fine except the go-home function.
    When I initiate this it won't ascend to the defined 50m height, but it starts flying back the same height it was before. Even stranger that it won't land, when reached the home it just hovers there.
    Any ideas?
    Thanks!
    ps.: (By the way it handles the top mounted gimbal like a champ... :) )
  2. Zac Eskelsen
    Zac Eskelsen New Member
    Jun 3, 2014
    26
    Page 68 of the manual
    "When initiated with the Home Switch, ALTA will fly back to the Home Point, and the pilot will maintain control of ALTA’s altitude the entire time. ALTA will not Autoland if an adequate signal is detected. The pilot can cancel the RTH procedure by commanding a pitch or roll command or by retuning the Home Switch to the middle position. The Mode Switch must be in Position Mode to activate RTH manually."
    "During an LOS event, ALTA will first check its current altitude against Safe Height. If it is lower, it will climb to Safe Height, and if ALTA is above Safe Height, it will remain at its current altitude. Next, ALTA will fly back to the home position at the RTH Speed set in the ALTA App. Finally, upon reaching the home position, ALTA will begin Autoland."
    If you want it to auto land it would need an LOS (ie. turning off the radio)
  3. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Thanks for that!
    I didn't mention that the same thing happens when I turn off the radio.
  4. Zac Eskelsen
    Jun 3, 2014
    26
    Have you waited enough time maybe, and is your Signal Loss Action set to RTH?
    Page 69 goes into detail about the Autoland
    AUTOLAND
    The Autoland function will command ALTA to hover for 10 seconds and will then land in place. If ALTA is above the app-configurable Safe Height setting, ALTA will first descend to it at the Maximum Descent Rate. After reaching this height, ALTA’s descent will slow to the Autoland Descent Rate.
    Autoland will only initiate if one of the following conditions is met:
    During Loss of Signal (LOS) if Autoland is selected as the LOS event in the ALTA app
    At the end of a LOS Return-to-Home event
    Battery exhaustion while flying in Height or Position modes only
  5. Zac Eskelsen
    Jun 3, 2014
    26
    Does it rise to the correct height at least when you turn off the Radio?
  6. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Hy,
    The same thing happens when I command the go home and when I turn off the radio.
    Both times the copter stays at the same height, fly back to the home point and hovers. It will not land even when I waited 2 minutes.
  7. Zac Eskelsen
    Jun 3, 2014
    26
    Unless somebody else has an idea, could you post a screenshot of your safety settings from the Alta App?
  8. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    I can do it tomorrow, thanks for the help!
  9. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Here are my settings:
  10. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Tested it today, still not working.
    Another question. Is it possible to not limit the max flight height? I can only set the value to 118m and thats not enough.
  11. Zac Eskelsen
    Jun 3, 2014
    26
    Someone else should confirm, but it is my understanding that the Flight Controller won't stop it from going beyond those limits you set, but will only show a Red LED light to indicate you have passed them. So even though there is a limit set in the app, you can surpass them.
  12. Zac Eskelsen
    Jun 3, 2014
    26
    I'm not sure why the Alta isn't landing on its own when you turn off your controller. your settings seem fine. Perhaps try emailing support.
  13. Gary Haynes
    Height/Position mode restrictions are 122m Height and 500m Distance. No limits in manual mode.
    Range set RANGE
    Range sets the maximum distance ALTA may fly away from the home point while
    in Position mode. If the range is exceeded in Manual mode, the status light will
    illuminate white.
    Height
    MAXIMUM CEILING
    This adjusts the highest altitude the ALTA is allowed to climb from its starting point
    while in Height or Position modes. If the maximum ceiling is exceeded in Manual
    mode, the Status Light will illuminate white.
  14. Gary Haynes
    I don't have mine powered up but in the screen shot you sent the Signal Loss Action is set to RTH. Change it to Land and it will land. Yours did what was programmed. Come home and hover.
    From the manual (first bullet)
    »» During Loss of Signal (LOS) if Autoland is selected as the LOS event in the ALTA
    app
    »» At the end of a LOS Return-to-Home event
    »» Battery exhaustion while flying in Height or Position modes only
  15. Zac Eskelsen
    Jun 3, 2014
    26
    If its set to Land, won't that make the Alta land at its current position? From my understanding of the manual if there is a LOS, and you have it set to RTH it will RTH and then land, but if its on Land, then it will just land in its current position. Is this incorrect?
  16. Andy Johnson-Laird
    10,369
    Gary: The manual seems a bit confusing.
    The manual also states:
    AUTOLAND​
    The Autoland function will command ALTA to hover for 10 seconds and will then​
    land in place.​
    So the way I'm reading it, in conjunction with the section on Return-To-Home, where the manual states that if the selection is RTH then:
    During an LOS event, ALTA will first check its current altitude against Safe Height. If​
    it is lower, it will climb to Safe Height, and if ALTA is above Safe Height, it will remain​
    at its current altitude. Next, ALTA will fly back to the home position at the RTH​
    Autoland.
    is that:
    1. If LOS and if option set to RTH, then ALTA executes return to home, hovers for 10 seconds, and executes an autoland.
    2. If LOS and if option set to Autoland, then ALTA executes hover for 10 seconds and autolands in place.
    Zac's experience is that this is not the case for item 1. above. It just hovers and never autolands.
    Let me email someone at FF about this and request clarification.
  17. Gary Haynes
    I re-read it.
    app
    So Adam time to send an enquiry to the support desk. With your settings and Andy's interpretation it should come home and then land since it is at the end of the LOS Return-to-Home event. That's what it did during Synapse testing but we didn't have a value to easily change for the event, Land or RTH.
  18. Andy Johnson-Laird
    10,369
    The words I get from People Who Know These Things are (and apologies I had put Zac's name in the first response):
    There is a difference between operator-commanded (normal) RTH and LOS RTH.​
    In normal RTH, the operator maintains control of altitude using the throttle input during the entire sequence. In LOS RTH, altitude is controlled by the Synapse, and will always autoland as the last part of the RTH sequence.​
    One thing about LOS RTH is that it requires using a receiver that can identify signal quality/LOS (S-Bus or DSMX). So if Adam's using a PPM receiver with a failsafe, autoland will not occur until battery exhaustion.​
    So my first question is what kind of receiver is Adam using?​
    Another thing to check is that the radio status reads LOS (Under Monitor > Status) when the radio is powered off and ALTA is on.​
    Adam?
  19. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Hy, So first of all.
    I have a Graupner GR-24 receiver and it's set to command the channel 7 to low, so the ALTA will come back.
    Regarding the position hold and height hold max height. I think this is kind of bad, when using position hold the user should be able to fly as high as he wants in my oppinion. I use height hold mostly but sometimes have to use position hold, and if I cannot fly above 118M in these that this is a very big problem for me. My Cinestar with WKM can easily do this. Please Freefly modify this, or at least let us set the max height to 300m at least. And this applies to max distance...
    I will make a video of the setup and the flying so you guys can see the problem.
    Another thing: We flew the Alexa Mini yesterday and with a small lens, small matbox and only a sdi-to-hdmi converter the gross weight was 15.4 kg. It flew well but I'm a bit worried about the wieght. What do you guys think?
    Thanks!
  20. Jan Evers
    Jan Evers New Member
    Feb 5, 2014
    22
    Adam,
    As you are using a Graupner, which is PPM, it will not detect a LOS event, and so it will not auto land...
    Concerning the weight: The Alta will handle it, but you have to have the awareness that your buffer of performance is reduced.
    Kind regards
