Hi, We flight every day, but it's not same flight if we change 0,5Kg in more, or the direction on the wind. If we flight in Height Mode or Position, the alta do vibration to Movi, and after the movi do more vibration to the alta. We try all the ring, we let the black for Red, Connex, lens ( 3,1Kg ) We change Stiffness 6 , Hold strength 70, in Attitude, Heigth position, it's better but not good !! We can put a Dji A2 inside ??
set everything to factory default and then lower vertical stiffness and vertical hold strength. after that you should be fine.
