ALTA 8 red flashing when trying to arm - SOLVED
Discussion in 'ALTA 8' started by Robert Marks, Feb 2, 2019.
  1. Robert Marks
    Robert Marks Member
    Aug 22, 2013
    60
    solved
    #1 Robert Marks, Feb 2, 2019
    Robert: For the benefit of other forum members could you explain a little more?
    The Ground Is The Limitâ„¢
  3. Daniel Waghorne
    Mar 8, 2018
    30
    Hey Robert,
    Would you mind posting what caused this? I've seen this happen before when trying to arm in Height Hold or Position mode, and then if the home switch was not set to the center position. Was this the issue, or was it something different?
  4. PJ Mozingo
    PJ Mozingo Member
    Dec 17, 2014
    55
    Not sure what solved Robert's issue, but I had a similar issue yesterday flying the Alta 8. I had flown 4 sets of batteries no problem, then when booting up on the next set, the status light went from red to white and then red. Once red, it started blinking slowly, then rapidly with no change. I couldn't arm or do anything. I tried another set of batteries and the same thing. Connected it to the Alta app and had a warning saying the compass wasn't locked. Weird, being that I just flew several batteries and not only had a working compass, but up to 10 satellites.
    I popped the Alta off the Movi and did the calibration and boom...it started working again! We moved down the road about 50 yards and when booting up, the same thing...rapidly red blinking status light. Re-calibrated the compass once more and it was off flying again! Not sure what would cause the compass to need re-calibration so suddenly like that, but when in doubt, connecting the Alta to the app should help point you in the right direction.
    Hope this helps?
  5. Andy Johnson-Laird
    Thanks for posting. Interesting -- I'm not sure what caused the problem, but your description of how to work around it will doubtless help other forum members.
    Cheers
    PJ Mozingo likes this.
  6. Rolands Zelders
    Jul 27, 2017
    40
    I have had exactly the same problem week ago. Just before changed gps module because of week satellites and I presumed it was because of that but your comment makes me thing it would be something different. Actually this was first time never noticed before so I hope it will not pop up again :D
