Alta 8 and Movi 5 with Mimic Controller
Discussion in 'MIMIC' started by Joe Gurkovich, May 30, 2016.
  1. Joe Gurkovich
    Joe Gurkovich New Member
    May 3, 2016
    My first post here, hopefully I'm doing it correctly. I recently purchased an Alta 8 with Movi 5 with Mimic Controller. After assembling the Movi with landing gear and attaching it to my Alta, I switched on the Movi and the Mimic and my Alta started spinning uncontrollably at a high RPM. I found out through another Facebook forum that you had to place your Alta on chairs of something for steady support to test out the Mimic. That worked fine, but I'm afraid to switch the Movi and Mimic on before my first flight with the Movi setup if the Alta keeps spinning at a very high velocity.
    Any insight from anyone on this would be helpful, I do not want to crash a $28,000 investment. Thank you in advance.
    When the ALTA is on the ground, the gimbal control unit tries to stabilize the MōVI, but, of course, it cannot because the legs are resting on the ground. You need to put the MōVI into kill mode until shortly after take-off.
    There are quite a few threads on the forum, so please do a Google search for: ALTA spinning
    Hope that helps
  3. Joe Gurkovich
    May 3, 2016
    Thank you Andy, I will explore this avenue.
    Joe: My apologies -- I should have said "do a Forum search..." not a Google search.
