ALTA 6 FPV Camera Doesn't Clear MoVI Pro Batteries
Discussion in 'MōVI Pro' started by Josh Lambeth, Dec 29, 2016.
  1. Josh Lambeth
    1,315
    216
    Does anyone else have this issue or am I the only one flying with an ALTA 6 and the MoVI Pro?
    Josh
    Peter Lay likes this.
    I'm not sure you're the only one, Josh, but you're certainly the first to report this problem AFAIK.
    Cheers for 2017!
  3. Damian Young
    Damian Young New Member
    Apr 3, 2017
    Were you able to find a solution?
  4. Mike Gentilini Jr.
    Aug 5, 2014
    45
    11
    Our FPV camera on our Alta 6 clears everything just fine. I don't even see the legs in my frame anymore when yawing around. Do you have a photo of your issue?
  5. Peter Lay
    Peter Lay Member
    Apr 11, 2015
    51
    Hi Josh, I run A6/Pro as well and have same problem with FPV camera. It comes into physical contact with the battery when panning.
  6. Damian Young
    Apr 3, 2017
    Which FPV Cameras are you all using?
  7. Mike Reid
    Mike Reid Member
    Jul 14, 2013
    126
    11
    I had the same issue and modified my doc camera bracket to get it up higher. All I did was drill 2 holes in the square bracket so I could get it about a 1/2cm higher up.
