Alexa Mini to fit M10
Discussion in 'MōVI M10' started by alec_caton, Jul 20, 2015.
  1. alec_caton
    alec_caton New Member
    Nov 19, 2012
    19
    Hi guys,
    Just a quick one, has anyone flown the Alexa Mini on an M10 instead of the M15..? I'm trying to work out if it's feasible, I've only had my hands on the Arri Mini prototype, but looking at the release notes, size and weight wise it looks as though it could cradle in the M10.
    I just see everyone raving about it being a match made in heaven with the M15, but there's not enough coin in the piggy bank for that just yet!
    If anyone's got some success stories or advice it would be much appreciated!
    Cheers,
    Alec
  2. Augusto Alves da Silva
    Augusto Alves da Silva Active Member
    Apr 16, 2013
    202
    39
    I believe that if the camera fits the craddle then you´ll be able to fly the Mini Alexa. Not heavier than RED so I don´t think you´ll have any problems. I have flown RED several times with Zeiss Master Primes FF so weight will not be an issue. You´d better start working out :)
    alec_caton likes this.
  3. alec_caton
    Nov 19, 2012
    19
    Thanks Augusto,
    I was just checking because I know the cradle of the M10 is much narrower in depth than the M15. I wasn't sure if this could cause an issue 'fouling' against the back bar if you were to tilt etc...
  4. Wolf Schiebel
    Wolf Schiebel Active Member
    Aug 15, 2012
    254
    67
  5. alec_caton
    Nov 19, 2012
    19
    Thanks Wolf! Exciting times, look forward to seeing how you get on!
  6. Wolf Schiebel
    Aug 15, 2012
    254
    67
    Hi all,
    after some tests with the Mini in minimum configuration (2xMAP-1, BAP-2) with a 75 wh v-mount battery on sidemount and Heden Carat ff the M-15 did very well. Weight of the cam in total with 28mm UP LDS was 5.5 kgs.
    This setup didn't fit on the M-10, too wide and to front heavy. Also the antenna from the Mini always hit the roll bar. So i would guess it works with an highspeed, old standard 35mm prime or CP-2s. Another possibility would be to use a lipo and loose the v-mount.
    Some pics attached.
    Best,
    Derek Cooper likes this.
  7. Chris Schuster
    Chris Schuster New Member
    Sep 22, 2012
    18
    Great photos, thanks for posting.
    Any idea what the power Lemo pinout config is so a lipo can be used for power ?
  8. James Adkins
    James Adkins Member
    Apr 13, 2013
    158
    21
    Ditto. Your timing is perfect. Need to mount this next week. Thanks
  9. Chris Schuster
    Sep 22, 2012
    18
  10. Wolf Schiebel
    Aug 15, 2012
    254
    67
    Hi,
    or see screenshot from the manual....
  11. alec_caton
    Nov 19, 2012
    19
    Hey Wolf!
    Thanks for all the pictures and information! Very very useful!! We'd be using our's on an aerial rig which I usually power the camera from a Lipo fixed to the landing leg, hopefully with that set-up and some EF CP.2's I can squeeze it in the M10....if not I'll have to save some pennies for the M15!!
    Thanks again for all the info and photographs! Really really helpful!!
    Cheers!
  12. Wolf Schiebel
    Aug 15, 2012
    254
    67
  13. Paul Christopher Greene
    Jul 28, 2013
    163
    13
    I've flown Alexa Mini on M10. It's very tight but doable. PM me if you need more info...best of luck
  14. Bryan Harvey
    Bryan Harvey Member
    Nov 3, 2012
    227
    18
    Hey guys, got a job coming up asking for Arri Mini and have not developed a setup yet for Arri on the drone/M10.
    So is it 4S lipos for the Arri Mini (same ones I use for RED)? Must I get a right angle leemo power connector, or is the straight one OK for a M10. We will be flying EF mount Leica R 16mm lens (the lightest smallest lens option).
  15. Wolf Schiebel
    Aug 15, 2012
    254
    67
    HI Bryan,
    yes, the 4S Lipo is possible, i would guess about 20 min runtime. An angled Lemo connector is a must.
    It should work alright with the small Leica lens..
    I would like to see a pic of the setup…
    Best and good luck,
    Wolf
