Alexa Mini Power solutions
Discussion in 'MōVI M15' started by michael duffy, Oct 17, 2015.
  1. michael duffy
    michael duffy New Member
    Jul 25, 2014
    11
    I want to figure out a way to cut some weight on my M15 using the Alexa Mini. I heard that you can power the camera with Lipo batteries. I searched the forum and googled around but didn't find much.....
    Do any of you guys have any info you could share on how to pull this off or anything to be aware of? I'm curious as to how much run time I could pull? I'd be using it for on ALTA as well as just regular land based gimbal work.
  2. Angus Benson-Blair
    Jan 23, 2013
    148
    25
    I bought an Arri Mini power plug (cant remember the exact details sorry) and plug this into a 4s 2600mah lipo. It lasts a flight so battery management is an issue but it certainly lightens the load.
  3. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    I've been using 6s 5200mAh and get a good 30 mins camera operation.
    Bought one of these, chopped it right back and put a flexible cable on.
    http://www.hawkwoods.co.uk/Prods/Product/XB-CAB5
    I need to work out a better way of fixing the battery to the gimbal, currently just using cable ties so a bit of a faff to change.
  4. Michael Elsegood
    Oct 26, 2013
    80
    20
    Michael, I've just order a couple of variations of the Media Blackout cables for Alexa Mini - A Dtap one and a XT60 one.
    I use their cables exclusively on our MoVis with great results - both for power and Video signal... As for run time, I can't comment until I've done some tests.
  5. Ben Platts
    Ben Platts Active Member
    Jan 24, 2013
    186
    25
    We just use the Hawkwoods PC-16 cable which I put a deans connector on. With a 4s 3300mah batt we get about 25-30 mins run time on the mini
  6. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    I bought the original KC-50 cable, shortened it, took off the rubber coating, and added an XT60 plug. Works like a charm.
    From a 4S 4200mah battery it can run the camera and 1 LCS for 25-30 min.
    (If you'd like I can take a photo of it and show the connection diagram)
  7. Michael Elsegood
    Oct 26, 2013
    80
    20
    Would love to see a picture of the Alexa Mini on your M15, Adam.
  8. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    Hy Michael,
    Here is a few pics:
  9. Michael Elsegood
    Oct 26, 2013
    80
    20
    Very cool. What is your total TOW with this setup? What size flight packs?
  10. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    TOW?
    Max weight was 15.5 Kg, flight time 11 min with 2x 10.000 TATTU.
    But the copter didn't really like the weight, it was a bit wobly, but flew well.
    Aj White likes this.
  11. AdamSculthorp
    AdamSculthorp New Member
    Mar 17, 2013
    15
    If anybody is looking for an Alexa Mini power cable we have some pre-wired to bare-ends. Will supply to any UK users...
  12. Guillaume MARION
    Dec 21, 2014
    77
    15
    How is that possible that you reach more than 15kg??
    4,6 = ALTA
    2,2 = M15
    0,150 = Connex
    0,5 = Power (just estimation)
    2,8 = 2x6s10000
    2,3 = Alexa
    0,4 = SDI / HDMI (just estimation)
    0,65 = lens (if it is what it looks, ZEISS 2,1)
    0,7 = Filter holder
    14,3 = Total
    Where I'm wrong??
  13. Adam Varadi
    Adam Varadi Member
    May 3, 2014
    156
    17
    I have a SDI-HDMI converter also, and that is 0.4 kg.
    But I don't know exactly the weight of everything. Here a a picture of my last setup. It was 15.2 Kg:
  14. James Adkins
    James Adkins Member
    Apr 13, 2013
    158
    21
    Don't waste your time with Media Blackout. They have been jacking me around for months. Their last response said they have no clue when they might deliver. Hell of a way to treat customers.
  15. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    I had a similar issue with Media Black Out, the delivery took months.
    Wooden Camera has one cable, it's not as flexible as Media BlackOut's cable but it works.
  16. Noah Stout
    Noah Stout New Member
    Aug 3, 2016
    15
    Hi All,
    Looking at this a year later. I have an Alexa Mini and just bought an M15. I'm looking for the lightest and simplest way to run it as it's pretty heavy right now. I have 1 or 2 d-tap accessories to run, and when not on the M15 I use Goldmount (so side mounting the battery with the BAP-2 or the Freefly one above isn't great. I'm thinking about going the Lipo route. What is the longest lasting Lipo that still fits in the M15 battery slot? And am I able to power both the Alexa Mini and a Redrock Follow focus off the same battery with a D-tap splitter?
    thanks!
  17. Aj White
    Aj White Member
    Feb 14, 2014
    82
    Holy moly this gives me hope... I haven't flown our Mini yet but now I'd like to try!
  18. Stefan Helborg
    Oct 11, 2015
    210
    How low do you drain your batteries?
    I flew about 10min with 13 kg with 2x 10.000 TATTU, and landed as it said 21,6v in the display. When I measured the batteries right after landing, they showed 14% and after about 20-30 min they showed 30-40%
  19. Stefan Helborg
    Oct 11, 2015
    210
