ALEXA M & MoVI M15
Discussion in 'MōVI M15' started by Ken Schijf, Sep 29, 2014.
  1. Ken Schijf
    Ken Schijf New Member
    Sep 24, 2013
    27
    I have a shoot coming up with both the Alexa M and the MoVI M15.
    I've never worked with the Alexa M, and I'm slightly worried about the umbilical cord pushing the camera and affecting the shot. - Anyone worked with this combo before?
    Also, as this will be my first shoot with the M15... Is the attachment of the top sliding plate a necessity? or if necessary can I not attach it should there be no cage etc....
    Thanks,
    Ken
  2. dan mohr
    dan mohr New Member
    Nov 25, 2013
    13
    Hey ken, not a lot of m15 field experience out there yet unfortunately, particularly w Alexa M.
    For umbilical concerns, smart strain relief and soft/flexible cables are your friends here.
    For top/bottom cage config, (Extrapolating from m10 experience), My guess is that you'll wanna attach at top and bottom for best results. ... eliminates any play in the single plate/connection and makes the camera mass "one" w the gimbal for stiffer settings etc.
  3. Ken Schijf
    Sep 24, 2013
    27
    Yeah, I remember having to use a belt clip to power the Red Epic long before the side v-lock plate was available... It was a nightmare, and lead me to use Red Volts for a good few months after that.
    I've just found a this: ... Hopefully the cable used wasn't a custom one.
  4. Peter Barta
    Peter Barta Member
    Sep 24, 2013
    75
    21
    Hi Ken,
    I've used the Alex M several times on commercials & film having had an M10 extended beta version and you really need the ultra thin cable between the body and head, Freefly put me in touch with FIS Blue Inc and I bought the correct cable which was the FIS Blue SMPTE311M Cable
    LEMO short FUW plug (no boot) [90o strain relief] -to- short PUW plug (no boot) [straight 15 feet (4.6 meters), NO Reel. It was around USD$900 but you will need it.
    You will also need to buy 1/4" to 3/8" Convert Screw Adapter for the Alexa M to mount your baseplate. Hope that helps.
    All the best,
    Pete Barta
  5. Wolf Schiebel
    Wolf Schiebel Active Member
    Aug 15, 2012
    254
    67
    Hi Pete,
    i had to improvise, see my short plug version, not recommended if you are unfamiliar with electronics and hacking stuff… ;-)
  6. Peter Barta
    Peter Barta Member
    Sep 24, 2013
    75
    21
    Hey Wolf,
    Glad you could make it work, most rental houses don't have the ultra thin cables.
    Best,
    Pete
  7. Peter Barta
    Peter Barta Member
    Sep 24, 2013
    75
    21
    Here's a pic of how thin that cable is for anyone who's thinking of getting one, I bought two one as a spare as they are very fragile.
    Lael Camak and dan mohr like this.
  8. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    Thanks for the info Peter!
  9. Wolf Schiebel
    Aug 15, 2012
    254
    67
    Peter Barta and dan mohr like this.
  10. Ken Schijf
    Sep 24, 2013
    27
    Thanks for the info gents.
    Arri has a stedicam cable I will be testing on Friday. I'm sure it'll do just fine... along with a right angle connector.
    Jason Herring likes this.
  11. Wolf Schiebel
    Aug 15, 2012
    254
    67
    ...unfortunatly there is no real right angle connector available. I even talked to LEMO about that at IBC. Just a right angle strain relief, which gives us about 3 more cm at least.... The cable i "hacked" in the pic above is the ARRI cable.
    Best Wolf
  12. Wolf Schiebel
    Aug 15, 2012
    254
    67
    Another pic from yesterday….
    Lael Camak and Peter Barta like this.
  13. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    like the pirate sticker! :D
  14. Ken Schijf
    Sep 24, 2013
    27
    Arri Media in London have one... thankfully!
  15. Wolf Schiebel
    Aug 15, 2012
    254
    67
    Hehe, i know that one. It's the only one exists and it's custom built by Arri.
    Good luck!
    Best,
    Wolf
    Ken Schijf likes this.
  16. Ken Schijf
    Sep 24, 2013
    27
    It got the job done :)
