Airframe setup. Not allowing to pick configuration
Discussion in 'ALTA X' started by Tom Lautenbach, Aug 20, 2020.
  1. Tom Lautenbach
    Tom Lautenbach New Member
    Apr 8, 2020
    Hi there, I am setting up my Alta X and it requires me to set up the airframe in Q Ground Control and it gives me the options to either select the pro or alta x frame but it is not allowing me to physically select it?
    please let me know any advice would be appreciated. Kind regards
    10,375
    Sorry to hear about the issue you're having, Tom. This forum is primarily intended for dialogue between Freefly's customers, not as a primary means of getting technical support from Freefly -- for that you need to open up a ticket with Freefly Support and the best way of doing that is to head over to https://freeflysystems.com/contact
    That said, when their workload permits, I do know that Freefly technical support will occasionally review some of the threads on the forum, but opening up a ticket really is the optimal way to get support.
    The Ground Is The Limitâ„¢
  3. Tom Lautenbach
    Apr 8, 2020
    I was able to fix this by re loading the parameter file from the Freefly support page for alta x
