aerials around Sydney
Discussion in 'ALTA Showcase (Photo/Video)' started by alex ryan, Jan 5, 2016.
  1. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    Here are a couple of edits from some flights around Sydney, Australia.
    I still haven't been able to get rock solid results from my M10 so I did apply some post stabilisation on these shots.
    Also the compression isn't that good.
    I would love to hear your thoughts
  2. Howard Dapp
    Howard Dapp Active Member
    Aug 18, 2012
    977
    111
    Good shots but personally I would not be satisfied until I'm able to produce post-stab free footage, after all isn't that why you spent so much coin? To get away from the old days where post-stab was mandatory.
  3. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    Agreed. Its getting much better the more I fiddle with the settings. Still having to use a bit of stabilisation, but I'm confident I will eliminate the need for it with a few more adjustments.
    Howard Dapp likes this.
  4. Tomasz Gladys
    Tomasz Gladys New Member
    Nov 3, 2015
    22
    Hi Howard, what would you recommend to change in Alta, Movi settings to achieve the best results of stabilization?
  5. Howard Dapp
    Aug 18, 2012
    977
    111
    I don't own an alta so I have no idea. Are you too not getting perfect results? Maybe an alta pro will jump in.
  6. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    here's the latest iteration of movi settings with no post stabilisation. its getting there. still have some vibration introduced by the alta, but i think thats just a matter of reducing the vert stiffness and hold settings a bit more.
  7. MathewHarwood
    MathewHarwood New Member
    Feb 14, 2016
    Hi Alex, I am also based in Sydney if you ever want to meetup and look at settings. M
  8. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    Hey Matthew,
    I've since got settings pretty good, but always good to know fellow local operators. Happy to meet up anytime to nerd out and share knowledge.
