Aerial stills with A7Rii in The Netherlands
Discussion in 'ALTA Showcase (Photo/Video)' started by Robbert van Weelderen, Apr 6, 2016.
  1. Robbert van Weelderen
    Mar 15, 2016
    74
    Some shots with my A7Rii. Still experimenting with the Movi/Alta settings for this camera. Getting very stable video on the FS5 which is a bit heavier but having more problems with the A7Rii so having to use quite fast shutter speeds on these ones. I'm very happy with the results (general sharpness on successful shots) compared to the Inspire 1 X5 camera.
    [​IMG]Farmland The Netherlands by Robbert van Weelderen, on Flickr
    [​IMG]Bomenpark by Robbert van Weelderen, on Flickr
  2. Jeff Scholl
    Jeff Scholl Distributor
    240
    50
    What shutter speeds are you after? Do you see any hi speed blur/vibrations when you shoot video from the A7rii?
    Cheers,
  3. Robbert van Weelderen
    Mar 15, 2016
    74
    I would like to go to shutter speeds around 1/100s, atm I'm pretty much stuck at 1/640 or faster to get consistent sharp results. I don't think I'm really getting a lot of hi speed blur/vibration but more constant movement of the image frame at a lower speed.
  4. Jeff Scholl
    240
    50
    What lens are you using?
  5. Robbert van Weelderen
    Mar 15, 2016
    74
    Both used the 90mm f2.8 Sony Macro and the Loxia 35mm and was seeing the same thing happening on both of them. I know that 90mm is really pushing it.
    (Above the upper two shots are with the 90mm and the last one is with the Loxia.)
