A7s riser for m5
Discussion in 'MōVI M5' started by Kevin Riley, Jul 24, 2016.
  1. Kevin Riley
    Kevin Riley New Member
    Jul 23, 2016
    14
    Im looking for a light weight solution to fit between the base plate and the A7s to give about a 5-8mm rise. I can make something up but equally happy to use a tidy pre existing solution. Any ideas?
  2. Derek Cooper
    Derek Cooper Active Member
    Apr 28, 2014
    527
    34
    Fat washer - nylon. It's what we do.
    Kevin Riley likes this.
  3. Freddie Murphy
    Freddie Murphy New Member
    Dec 8, 2014
    17
    I use a SmallRig cage for my A6300. It raises the camera enough for the Movi plate to not rub the lenses.
  4. Ricardo Mor
    Ricardo Mor Member
    Jan 9, 2015
    37
    Derek Cooper, which Size of Fat washer do you use for the MoVi M5 ?
  5. Kevin Riley
    Jul 23, 2016
    14
    Yep nylon washers from plumbing supply did the trick
  6. Ricardo Mor
    Ricardo Mor Member
    Jan 9, 2015
    37
    Ian trying a fat washer in Steel / Zinc (Galvanized). It doesn't effect the GPS or Motor, right?
    Other idea is to cut a Foam rubber sheet.
  7. Ricardo Mor
    Ricardo Mor Member
    Jan 9, 2015
    37
    Here it is
