A little radio help needed.
Discussion in 'MōVI Controller' started by James Bass, Jan 29, 2017.
  1. James Bass
    James Bass New Member
    Dec 1, 2016
    16
    James take a look at the Futaba 14SG. Easy to setup. Model file can be downloaded and installed from Freefly or others here on the forum who have a copy. If you are unfamiliar with RC radios my personal opinion is that it would easier to setup than the Spektrum.
    James Bass likes this.
  3. James Bass
    Dec 1, 2016
    16
    Thanks for the info Gary!
    I was hoping to keep the costs down as it is most likely something that I won't use that often and don't require any sort of camera control. With that what are your thoughts on the Futaba 6J?
    https://www.bhphotovideo.com/c/product/1062198-REG/futaba_futk6000_6j_2_4g_radio_with.html
    Thanks again!
  4. Gary Haynes
    That would likely work since you need 6 channels to control the MoVI. I don't have any experience with it. Also if you go the Spektrum route you will want a receiver that can do 'PPM'. PPM allows for a single wire connection to the receiver. Not sure that the DXe comes with the right type of receiver. Worth an email to support@freeflysystems.com to verify that the TX/RX setup you are thinking about will work.
    Spektrum would need PPM RX or a 'Satellite' RX while the Futaba would need sBus.
  5. James Bass
    Dec 1, 2016
    16
    Thanks Gary, I appreciate the help!
  6. Rolands Zelders
    Jul 27, 2017
    40
    Do you still have the file? Can not find it. I urgently need one
  7. Andy Johnson-Laird
    10,364
    Here's the model file for the Futaba 14SG but it's completely incompatible with the 6J, I suspect. My next strategy would be to search to see if Futaba has any kind of model file converter so that you can change the format of the file to one for the 6J.
    See http://forum.freeflysystems.com/index.php?threads/rather-good-guide®-to-installing-and-configuring-the-futaba-radio-on-the-alta-6-and-8.7821/ -- I know the guy who wrote the guide and most of the time he's right (and what he lacks in accuracy he makes up for with enthusiasm). :rolleyes:
    Cheers
  8. Rolands Zelders
    Jul 27, 2017
    40
    Thanks Andy but I need a model file for MoviPro not Alta
  9. Andy Johnson-Laird
    10,364
    Oh. My bad. Let me see if I have that.
  10. Andy Johnson-Laird
    10,364
    I've contacted the Chief Movi Whisperer, Bryan at FF and asked him if he can post the file -- I don't have it, sorry.
  11. Rolands Zelders
    Jul 27, 2017
    40
    Thanks Andy. How do you guys done it before?
  12. Andy Johnson-Laird
    10,364
    Hi Rolands:
    Apologies -- I'm not quite sure what your question is. Could you restate it, please?
    Cheers
  13. Rolands Zelders
    Jul 27, 2017
    40
    Sorry, the question was - How you program transmitter for gimbal operations?
  14. Rolands Zelders
    Jul 27, 2017
    40
    - is this a too personal question to ask?
