Nice work Sebastian. Where did you get the remote and monitor mount bracket from? I've not ventured into the world of RC anything before, so would appreciate any help I can get. cheers Garry
Sure looks a lot like this http://www.aliexpress.com/wholesale...mount&catId=0&initiative_id=SB_20130925185122
That's the one ... It's not a favorite amongst some, but I like the minimalism of it .. Keeps the system lighter. Not too keen on the tray systems. The only modification I've made since that video was putting some extensions under the base plate to raise the LCD up. It also moved the lipo that powers the LCD further away from the receivers antenna. There is a discussion on mounts and trays here http://forum.freeflysystems.com/index.php?threads/drop-the-hot-shoe-bracket-that-lcd.1909/
Sebastian are the uplift tubes the same Axial Posts that you can buy if you need to raise your battery tray on the CS?
Gary, Nope, I used 100mm threaded aluminium bolts and then some heatshrink tubing over them. I could not find standoffs long enough, the longest were 70mm I think. But theses seem to do the job.
Hi. A big thanks for the info response to my question. They sure do have a lot of gear. Hopefully they'll ship to Australia. Cheers and thanks again. Garry
