A litte bit Oscillations ok?
Discussion in 'MōVI M5' started by Ricardo Mor, Sep 15, 2016.
  1. Ricardo Mor
    Ricardo Mor Member
    Jan 9, 2015
    37
    Hi Guys,
    i made one little Video to demonstrate my "problem"
    Do You see Oscillations on the Pan axis? Is this normal?
    These are autotune values.
    Are you confirm with the Tuning settings?
    Set Up: Sony a7s, zeiss Compact Prime, redrock follow focus, PIX-E7 Monitor, Redrock Base station, MoVi M5
    EDIT: Sorry for the Bad quality:
    Autotune: 70 %
    Pan: 134 Roll: 37 Tilt: 60
    Filter: 10 5 1
  2. Dominic Eder-Smigura
    Oct 17, 2016
    10
    Hey Ricardo! I had the same problem. Some pan moves would result in oscillation and the noise meter on the app would go up like in your video. I simply backed down the stiffness settings and the oscillation went away. Pan stiffness of 134 is quite high. You could try to lower it a bit. It really depends on a lot of factors but I get outstanding stabilisation at a much lower pan stiffness value.
    Dominic
  3. Ricardo Mor
    Ricardo Mor Member
    Jan 9, 2015
    37
    Hey Dominic,
    thanks for reply. Okay i will try it! Thanks a lot!!
